Development and testing of modified XNU Kernels for AMD CPUs on OS X
#12000
I'm going to share my kernel patch files here. These patches are modified from older versions of macOS (OS X) from AnV, Bronya, Sinetek and the VoodooTeam. Also thanks to Spakk and Duran Keeley for helping along the way.
You only need to download these if you wish to build the kernel or if you want to see how it's done.
xnu-3248.60.10 is El Capitan 10.11.6 and xnu 3789.21.4 is Sierra 10.12.2
Update: Added my 10.13 source (xnu-4570.1.46-Shaneee). There's no Ryzen support. If someone could help add it send me a PM.
(118.86 KiB) Downloaded 40 times
(92.83 KiB) Downloaded 54 times
(333.94 KiB) Downloaded 33 times
