by: Sev4rik
#10184
Anyone overhear of this ?
I have it installed on my laptop, pretty cool and somewhat useful.
I was thinking about using the OS as a backup OS for my mackintosh, but I don't know what steps need to be taken in order to accomplish this goal.
Dan
#10198
Sorry I'm not entirely sure what it is you're asking. You can make backups on your main machine.
by: Sev4rik
#10203
Well, I mainly wanted to know if anybody has ever used this OS with a Hackintosh before.
#10223
Snow Leopard yeah. I had a fully working 10.6.8 (x86_64) install using a retail install CD so it definitely works. It takes alot of patience though.
by: Aaragon
#29682
I'm looking at installing snow leopard on my machine (as its the only version I have a copy of on disc) - before I get into it, do you think it will work?
My machine bits and bobs should be listed below if I added it correctly..
GK208B [GeForce GT 710]
Hello! I have used this configuration https://fo[…]
Hello! I have used you configuration and was able[…]
I got this issue even without a photo library. I&r[…]
