by: bloodsucker
#41999
I've finally installed the OS but I've got monitor problem saying "Unknown Monitor" and it only has 1024x768 resolution. Is there any workaround on this problem?
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
I have a hp6305 with X740 AMD CPU and a Geforce 31[…]
